Sapphire clocks
My speedo needle is a bit jumpy so ive been looking into getting a new set of clocks. Ive got an E plate RWD sapphire and the clocks have a boost gauge in the top left corner. Ive just been looking around to find a direct replacement and came accross this thread:
https://passionford.com/forum/ford-s...gauge-2wd.html
It seems that the sapphires never came with a boost gauge? ive looked through all my cars history and receipts and theres none in there for a change of clocks.
Is it possible that really early saphs had the 3door clocks and wiring?
Maybe but unlikely, the car is 25 years old so someone could've changed them over during that time. Never seen or heard of that being available from the factory. how long have you owned it?
I may change them back to original then as thats the route im going down with the whole car.
They are 3DR clocks, as you say the Saph didn't have a boost gauge, the reason being is it would not fit in with the cars executive image.
You can easily distinguish MK1 clocks from MK2's, the latter look completely different, also the battery warning light in a different place.
Martin
Martin
Mr S1
20
Sep 27, 2015 04:06 PM
