Lowering a ford focus mk1
Old Feb 11, 2014 | 02:52 PM
joshsparkes's Avatar
joshsparkes
Default Lowering a ford focus mk1
Hey guys I was wondering of you can help, I'm looking to buy some springs to lower my car. I'm currently rubbing 17" wheels and was hoping to lower from standard height down 40mm. Any advice is appreciated. If you have any pictures and could state how much you lowered that would be amazing. Thanks .
Old Feb 11, 2014 | 02:57 PM
gjh's Avatar
gjh
What sort of advise would you like? How to do the job? You should be ok with lowering it 40m as there is loads of arch space on the focus, if you aint sure how to do thejob get yourself a haynes manual, its a simple enough job to do, just unbolt and swap over really. Have a look in the pictures section of this forum, theres bound to be a few threads there on focus's that will show lowered ones. Hope that helps.
Old Feb 11, 2014 | 02:58 PM
joshsparkes
Okay thanks. I was wondering if it could be lowered on 17inch wheels with a tyre of 205/40 to 40mm. My wheels are spaced out to and come out further than the cars body. Thanks.
Old Feb 11, 2014 | 03:00 PM
gjh's Avatar
gjh
You should be fine, get some pics up when it done!
Old Feb 11, 2014 | 03:01 PM
joshsparkes
Thank you .
Old Feb 11, 2014 | 03:27 PM
STeve's Avatar
Super Moderator
Why would you space wheels out further than the body as its a mot failure for one unless your going for the chavtastic illegal carlos fandango look or do you simply have the wrong offset wheels to start with ??
taylora1409
Aug 12, 2015 12:06 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
