Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Exhaust size
Old Feb 10, 2014 | 08:31 AM
timsrs's Avatar
timsrs
Default Exhaust size
I am comming to the point where i need to look at the exhaust system on my Mk1 cossie conversion.
I am looking at getting a 2.5" system all the way through from the turbo.
the reasons are lack of space and i want more torque from lower down the rev range.
The car has a T34 with .48 exh housing.
running approx 370-380 bhp on siemens injectors & harvey gibbs chip....
Whats your thoughts on the 2.5" downpipe, i think this is the standard exhaust bore size....
cheers Tim
Old Feb 13, 2014 | 08:16 PM
jamie956's Avatar
jamie956
cheers Tim
You will need a 3'' system for that spec, and if you having one made make sure you have a boss put in for lambda sensor. will help for set up/mapping.
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
