Oil temperature sensor
Old Feb 9, 2014 | 09:38 PM
surrey_100e's Avatar
surrey_100e
Default Oil temperature sensor
I need an oil temperature sensor with a 1/8 npt thread to fit in my dry sump tank.
Can anyone recommend one? I've heard I can use a Bosch water temperature sensor would that be okay?
Martin
Old Feb 9, 2014 | 10:06 PM
JOHNDQ's Avatar
JOHNDQ
Had you looked at the Rspec ones been using these for a while but will depend what resistance your gauge needs
Old Feb 9, 2014 | 10:15 PM
stevieturbo's Avatar
stevieturbo
C**t
http://www.efi-parts.co.uk/index.php?productID=125
Not the NPT thread, but an option ?
http://www.jti.uk.com/product/engine...rature-sensor/
More expensive, but a combined pressure and temperature sensor. Obviously if it's in the tank though it will be of little use as far as pressure goes.
http://shop.scoobyclinic.com/index.p...product_id=525
Old Feb 10, 2014 | 02:57 AM
jon@work's Avatar
jon@work
VDO sensors with 1/8 NPT threads:
part number 323-801-005-001D has a max temp of 120 degrees C
part number 323-801-090-001D has a max temp of 150 degrees C
If you're wiring them to a digi dash, I've got the calibration curves for both.
Merlin Motorsport stock VDO parts, and have ordered parts for me from VDO in the past if they aren't a standard stock item. They do list the second sensor above:
https://www.merlinmotorsport.co.uk/p...d-323801009001
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
mike elsome
Sep 14, 2015 04:08 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
