What offset wheels do i need with 2wd cossie brake set up?
Old Mar 24, 2005 | 08:43 PM
gavintwopies's Avatar
gavintwopies
Default What offset wheels do i need with 2wd cossie brake set up?
As above i have been out and done all the necessary work to get some cossie 4 pots and discs on to the front of my s2.
Only the problem now is that when i went to put my wheels back on, the back of the spokes hit the caliper as i didnt check this before doing any of the work.
With them being after market wheels i thought that the style of the wheel might be the problem?
But saddly no......................as my std s2 7 spokes dont even clear the calipers either.
It looks like i need 10mm spacers or so which is a bit extreme just to get the wheels on in my eyes.
So does anyone know what the offset on a 2wd cossie rim is ??????
cheers ppl
Old Mar 29, 2005 | 04:53 PM
turboloon's Avatar
turboloon
i did the same conversion on my s2 i take it you machined the caliper 4mm?i've got 15" momo arrows and they're close but don't hit....
Old Mar 29, 2005 | 04:56 PM
Wazzzer's Avatar
Wazzzer
My League 067s hit the caliper as well mate, think its just something that happens with this conversion.
I used 5mm spacers and its fine now
Strangely enough I put my brothers Zetec S wheels on mine and the wheels cleared the caliper fine....
Old Mar 30, 2005 | 08:53 PM
gavintwopies
DIDNT MEASURE MINE IN MM WHEN I DID THEM I TOOK .180" OFF ABOUT 4.5 MM.
Old Mar 30, 2005 | 08:55 PM
gavintwopies
WISH IT WAS THAT EASY WITH MINE LOOKS LIKE I NEED 10 TO 12MM SPACERS.
DO YOU THINK IT WILL UPSET THE HANDLING TO MUCH???
Old Mar 31, 2005 | 07:51 PM
ze-vh phil's Avatar
ze-vh phil
just a quick one, i've got a set of 2wd 4pots and am planning the same, is it right you need to have new ends made for your brake lines?
thanx.
Old Mar 31, 2005 | 09:43 PM
gavintwopies
thanx.
Yes thats rite m8 also the lines need to be a shade longer too as the point of entry on the caliper for the fluid line is on the inside next to the cv not much room spare so a banjo style fitting is what you need
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Aug 10, 2015 12:08 PM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
