starter solenoid current
Old Feb 9, 2014 | 12:32 PM
jamie956's Avatar
jamie956
Default starter solenoid current
Any one know how much current a starter solenoid will draw.
Old Feb 10, 2014 | 07:28 PM
cabriolet's Avatar
cabriolet
what starter what voltage [what kilowatt rating is the starter] need answers to these questions , anyone who says its bla bla bla without the info would be foolish
Old Feb 10, 2014 | 08:27 PM
fraser9764's Avatar
fraser9764
And why would the kilowatt rating of the starter motor effect the current drawn by the starter solenoid?
Personally I think it is foolish to not read the question properly
in answer to the OP, i guess you are rewiring and want to know what size wire to use? Measure the resistance of the solenoid, and do 12 divided by the resistance, then add a bit as a safety margin. This is assuming you are talking about a 12v system
At a wild guess I would say it will be less than 1 ohm resistance and pull about 20a, but measure your starter to be sure.
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
