Escort RS2000 engine swap
Old Feb 8, 2014 | 04:07 PM
skoda169's Avatar
skoda169
Default Escort RS2000 engine swap
Bought an RS2000 but sadly it's to far gone to put back onto the road
however I have a MK5 XR3i stone mint shell would or could the running gear be fitted into the XR3i shell without to many problems or would it just be one big headache.
The RS2000 is complete and running without fault just a shame to have an excellent engine lying doing nothing
any advice comments would be good thanks
Old Feb 8, 2014 | 06:48 PM
Mk4 Rick's Avatar
Mk4 Rick
Get it swapped over.Is it 2wd or 4wd?
Old Feb 8, 2014 | 08:03 PM
Oranoco's Avatar
Oranoco
The Rs2k is a bit of a limp one. Break it up and make some cash and then fit a 2 litre Zetec to the 3i with a few tweaks or a turbo conversion
Old Feb 8, 2014 | 08:59 PM
JOHNDQ's Avatar
JOHNDQ
Nothing wrong with a RS2K engine got one as a track car standard other than a super chip had no trouble out dragging a ST150 on the straights. Are the cars both face lift or non face lifts other wise wiring is a bit of a nightmate. I was in same boot my early RS was to rotten to fix so swapped everything other to a face lift 1.3 shell
Old Feb 8, 2014 | 10:54 PM
Oranoco's Avatar
Oranoco
There's nothing wrong with it like you say just, imho, there are better engines to be had for less money, that are lighter and more readily catered for by after market parts companies
Old Feb 8, 2014 | 11:06 PM
JOHNDQ's Avatar
JOHNDQ
Guess it depends what the plan is, i cant think of a Ford 4pot he could put in standard without mods that will give the same performance that will bolt into a Escort plus if stuff already there from the RS wont cost much.
Old Feb 8, 2014 | 11:13 PM
Oranoco's Avatar
Oranoco
True enough mate.
Old Feb 9, 2014 | 10:48 AM
snoopaloopa's Avatar
snoopaloopa
Easy enough to do even if its a mk6 into a mk5, engine they should have put in the 3i's from the factory i reckon.
JoeyBoyden
Jan 4, 2024 02:36 PM
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
