Turbo flange help
How much did that cost?
This flange must come standard fitment on something? Then i could just buy an old downpipe and just chop the flange off.
As said above you could easily get that laser cut, you've got all the dimensions so you would just need to let the laser cutter know the thickness. The laser cutter I use has a minimum order charge of £40 but depending on the thickness you could probably get about 6 cut for that then you could sell the rest on eBay.
Ralph at www.componentengineering.co.uk will be able to cut them out for you and at a sensible price. Whether waterjet or laser cut.
Sounds like it could be a modernish diesel turbocharger ?
or some of the Mini guys seem to go down that turbo route
http://www.turbominis.co.uk/forums/i...=vt&tid=550571
http://www.turbominis.co.uk/forums/i...=vt&tid=491799
I got these bits made by Ralph and I have now recieved them and I am well happy with the results, would highly recommend him! Much cheaper than I thought as well!
He can make all sorts of things, from all sorts of materials ! Always excellent service too.
JK12
33
Apr 26, 2021 12:09 PM
