ecus, deep or 2fcd
Old Feb 2, 2014 | 09:10 PM
RSGooner's Avatar
RSGooner
Default ecus, deep or 2fcd
Which is the better ecu to use on a 2.0 conversion or is there not much difference, thanks
Old Feb 2, 2014 | 11:42 PM
Oranoco's Avatar
Oranoco
iirc when doing a 2 litre silvertop swap you want a DEEP, DESK or DEWY ecu
Old Feb 3, 2014 | 07:11 AM
RSGooner's Avatar
RSGooner
Thanks for reply, it's a blacktop, the plastic looking cover one does that make any difference?
Old Feb 3, 2014 | 07:57 AM
Oranoco's Avatar
Oranoco
We're running an St170 engine on a DEEP ecu so you may be ok, not all that up on the black top
Old Feb 3, 2014 | 08:27 AM
RSGooner's Avatar
RSGooner
Thanks again mate, will get them swapped over as running 2fcd at the minute, should get more power I would imagine then from deep
Old Feb 4, 2014 | 07:49 PM
RSGooner's Avatar
RSGooner
Another question, I have the 2fcd in car at the moment, would the deep plug into that loom which I believe is rs1800 loom or would I need different loom?
Steve Cooper
Sep 15, 2015 04:39 PM
Dahl88
Aug 22, 2015 08:16 PM
M Brian
27
Dec 1, 2004 10:08 PM
Apr 10, 2004 02:32 PM
