Trailing arm bush failure symptoms?
Old Feb 2, 2014 | 11:44 AM
R5FORD's Avatar
R5FORD
Default Trailing arm bush failure symptoms?
Whats the symptoms of these bushes failing or failed? Id like to check mine before spending £150+ lol 3dr cossie for anyone whos not aware
Old Feb 3, 2014 | 08:46 AM
opposite lock's Avatar
opposite lock
Probably a lot of flex and movement but is difficult to tell. I put money on it the car would be noticeably better with new ones and not nearly 30yrs old .
Definately want them for mine as mine isn't as 'solid' as it could be but still ok. Its gonna be money well spent imo.
Old Feb 3, 2014 | 09:05 AM
R5FORD's Avatar
R5FORD
yh it feels all over the place and iv still got this issue of my wheels getting lost in the arches when backing out my sloped driveway etc hoping a set of new trailing arm bearing bushes and poly beam mount bushes will transform the back end.
Old Feb 3, 2014 | 11:08 AM
Marc sierra's Avatar
Marc sierra
It will wander, especially at high speed. And during braking it will be instabile because it will pull the rear wheel into a toe out position if there is play in the bushes.
Old Feb 3, 2014 | 11:29 AM
R5FORD's Avatar
R5FORD
I'm hoping this issue i have is cured by changing the bushes its not so bad now as i have changed from konis to coil overs but imo shouldnt be this drastic even on Konis as i never had any issues with my saph running this setup nor does my dad in his 500.. this is just pulling out my driveway on a slight incline.
Old Feb 4, 2014 | 03:06 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Aha your car is B1GBHP! I recognise those wheels from the SFS show pics!
Is this Kev's old shell?
Old Feb 4, 2014 | 04:25 AM
When mine were worn. I could feel the side to side play in the arms. Have you got a poly diff mount??
Old Feb 4, 2014 | 05:39 AM
R5FORD's Avatar
R5FORD
Yh chop thats kevs old shell that i stripped and had repainted etc
Glenn, yhep i have a poly diff mount its done 70miles so i know thats not the problem unless its been installed incorecctly but dont see how thats possible /
Old Feb 4, 2014 | 07:34 AM
doga-ot's Avatar
doga-ot
If its a floflex mount i would take it off and check it
Old Feb 4, 2014 | 07:36 AM
doga-ot's Avatar
doga-ot
When my rear bushes went in my saph whilst driving over 40 i could feel te rear end trying to wander
Old Feb 4, 2014 | 08:14 AM
R5FORD's Avatar
R5FORD
Im not sure which mount it is its one i gor from Mile rainbird.
Yh i feel that at slower speeds feels aa if the rear is seperate to the front
Old Feb 4, 2014 | 08:49 PM
Marc sierra
Are the big bushes in the beam OK? On the pics it's very difficult (at least for me) to see any angles, so difficult to judge whether it looks weird or not.
Old Feb 5, 2014 | 03:56 AM
R5FORD's Avatar
R5FORD
Hi Marc, I know its weird as we have 2 other cars thats come out the same driveway and none do that.
Iv got new standard ford beam bushes but have just ordered some poly onesand orderd original trailing arm bushes hoping to have them here early next week.
Old Feb 5, 2014 | 04:25 AM
I spoke to loads of people about what bushes to fot the these arms. Some say only fit the orginals and ive spoke to people with poly bushes fitted and they say they cant tell the difference.
Old Feb 5, 2014 | 07:49 AM
R5FORD's Avatar
R5FORD
I know mate, rule of thumb is change the beam bushes to poly and the trailing arm ones replace with originals.
Old Feb 5, 2014 | 08:00 AM
charlie luciano's Avatar
charlie luciano
Replied in the Sierra room too car will wallow around on the rear especially under hard driving/braking
Luciano
Old Feb 5, 2014 | 09:40 AM
Marc sierra
On the pics it's very difficult to see what happens. Basically I can only see on one side the suspension compresses and on the other side it decompresses. But I cannot see any toe or camber angles.
Old Feb 5, 2014 | 04:42 PM
DAN-Saff's Avatar
DAN-Saff
Bushes won't cause that and that IMO is not a problem suspension is articulating what else do you want?
I think the corner weights are all over the place due to coilovers causing handling problems which is making you think it's wrong.
You can check by parking on flat floor take measurements from floor to arch front and rear
then jack the front up from the centre of crossmember wheels off floor 2 inch take measurement on the back
Repeat on rear jacking on center of diff and measure front arches.
The compression measurements on the front axle and rear axle will give you an indication of weight each wheel is carrying.
Adjusting it is another longer story.
Old Feb 5, 2014 | 07:39 PM
R5FORD's Avatar
R5FORD
Dan i understand that however its done that with Konis aswel as coilovers.. And i habe 2 other cars iv put in th exact same spot which didnt do anywhere near the same.
Old Feb 6, 2014 | 09:09 AM
DAN-Saff's Avatar
DAN-Saff
Are they identical? Strut braces etc.
You can check the bushes like they do at the mot - with a lever bar to check for movement. I really don't see what the problem is with that travel or the fact one car does it and the other doesn't - maybe the other 2 cars are wrong and the springs have sagged that much they stay flat? Or the arb are weaker and they aren't influence they chassis as much, or maybe your shell is stiffer etc.
When you fitted coilovers how did you set them up, because the only problem you've said is the handling is disconnected.
Old Feb 6, 2014 | 09:52 AM
Rsmat's Avatar
Rsmat
Originals or GGR ones cure the movement.. id never poly bush the trailing arms ever again... to much movement through bends and at high speed
Old Feb 6, 2014 | 11:58 AM
opposite lock
^ this, my mates old 4x4 sierra didnt feel right on bends IMO. Brand new poly items with coilovers.
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
