RGV250 motorbike project
Another new project to go with the sierra, bought this today, RGV250, its been used as a parts bike after the previous owner crashed his, gona get it running for this summer then tidy it up next winter
Also need to pass my bike test haha
This what it looks like now
Couple of photos with the parts to be re-fitted
And what is should look like
Nice one still got my rgv125 pepsi that i had brand new in 1990.
Loverley bikes,i seem to recall dont overfill the 2stroke oil tank as the overflow pipe exits on the back tyre??????
Arite so i got alittle bit done today, started by wire wheeling the old exhaust down till the drill broke, then painting it with VHT paint, also fitted the ends cans, theyre abit rough but theyll do for the summer
Ooh, i also fitted the rear seat plastics
Also fitted the headlight and painted/ fitted top yoke or what ever its called
Ok so its been a while since i updated this but ive been busy working on the Cosworth and doing DIY and sitting on my arse, first off i had trouble with it only firing on one cylinder and sombody sujestest it could be the power valves (it wasnt) but what a ball ache to remove the old screws, had to weld a nut to the top of the screw
It worked though
It worked though
Ok so its been a while and its still not quite finished, i still need so brackets that hold the fairings on.
But i have replaced the rear shock as it had no damping, it was just springey
Old one appers to be missing the external resivour
New CBR600 shocker
Fitted fairly easly, took about 30mins
Also old reg plate
New smaller one, might get the next size up?
There more been done but photobucket is pissing me off. Also been doing a little work on the Sierra
New CBR600 shocker
Also old reg plate
don't go too small on the number plate.. No point getting pulled for it being silly small..
smallest I went on my older bikes was 7x5 (pre current reg numbers) and I currently run with an 8x6 on my current bike which is a '2010' model. Looks neater and fits the back end nicely without being so small that it takes the piss..
2p
2p
2p
2p
Probably a 7 day rectification notice and Ł60 fine and the risk of the vehicle being taken if you get caught too many times for the same thing.
7x5 on my old ZX6R, it was only a 2 digit number so could go a bit narrower but even that maybe on the small side these days.. It was 'a few' years ago now
8x6 on my latest bike
HTH
HTH
Reflector is a legal requirement for a bike but I didn't like the ugly bolt on one that came with the tail tidy that would have meant 2 more holes in my nice plate.
I need to get another one to stick to the standard size plate that I will have to re-fit for MOT time.. They are cheap enough from local bike shops or Ebay..
ZX6r is long gone.. Prob had 5 or 6 bikes since that one but it's has some fond memories attached to it as it was my first 'sports' bike.. first track day, first knee down etc etc..
I had an RGV250 a few years back, was the white one with the bright graphics, think it was a 93/94.
Best bit was I only paid Ł100! Guy at work managed to break the chain and in turn that damaged a couple of other bits. He'd neglected it a bit and i went through the whole thing, power valves were seized etc. the bodywork was really clean, sold it for Ł1200 which is probably cheap these days.
Also gave it alittle clean today, anyone anygood with photoshop?
Thinking of going with while wheels if anyone could change them, possible a couple of other colors, gold, silver etc
