Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Ford fiesta mk 6 1.4
Old Jan 30, 2014 | 09:44 AM
Fordmk2396's Avatar
Fordmk2396
Default Ford fiesta mk 6 1.4
I was thinking about putting 17" rims on my car and only have 15" at the moment, will i have to change anything else if i put bigger ones on or will it be alright?
Old Jan 30, 2014 | 10:22 AM
doga-ot's Avatar
doga-ot
It will be ok you will need to use the correct tyres so your speedo is reading right but theyre always out a bit anyway
Old Jan 30, 2014 | 10:46 AM
Fordmk2396's Avatar
Fordmk2396
Cheers, also the wheels i am buying are off an astra but previously on a clio, would the stud pattern be the same?
Old Jan 30, 2014 | 11:01 AM
Cardie's Avatar
Cardie
Fords are 4x108, Vauxhall are 4x100 but I think they squeeze on okay from memory, if havent had new brake pads recently? Ive put ford wheels on a ford, changed the brake pads and they all of a sudden dont fit across the caliper because the offset is wrong!
Old Jan 31, 2014 | 02:08 PM
minder's Avatar
minder
vauxhall wheels wont fit your car mate they are about 5mm diameter out don't look
that much when you try and fit them but no way will they fit
borboyous
Aug 22, 2015 11:17 AM
loughlin1
Ford Fiesta
Aug 20, 2015 10:42 PM
Botts
Aug 13, 2015 04:16 PM
