Anyone have any dealings with pajero swb's 2.8
Old Jan 27, 2014 | 07:36 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Default Anyone have any dealings with pajero swb's 2.8
Thinking of buying one in white with the big wheels and arches all the import bits only thing that let's it down that's not really a problem is it's an auto
Old Jan 27, 2014 | 11:31 PM
Rax's Avatar
Rax
I had a UK wide arch LWB man for 12 months.Did what it supposed to and comfortable,19-22mpg. Problems I came across with mine and on a good forum was.Fuel sender packing (easy repair) issues with the 4wd.The actuator seizing up through lack of use so you could engage 4wd but no diff lock I think.The biggest issue I came across was them starting and then stopping first thing in the morning then once run again fine.It pointed to the seals on the pump apparently on the 2.8 anyway.Have look on here loads of info and helped me
http://www.pocuk.com/
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fiddy
21
Sep 29, 2015 06:10 PM
rsguy
44
Sep 29, 2015 03:29 PM
PeterLucas
Sep 21, 2015 11:36 AM
Flatlinedan
Sep 18, 2015 12:41 PM
