Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
st170 gearbox swap?
Old Jan 27, 2014 | 06:04 PM
xr2imetalhead's Avatar
xr2imetalhead
Default st170 gearbox swap?
i am just wondering if the st 170 gearbox is a straight swap into a 2000 2.0 mk1 focus ?
Old Jan 27, 2014 | 06:36 PM
blueovalman's Avatar
blueovalman
I belive you need to change the driveshafts and possibly the hubs for the 170 gearbox to fit, also the gear linkage
Old Jan 27, 2014 | 06:56 PM
xr2imetalhead
cheers thanks for the information matey
Old Feb 1, 2014 | 06:53 PM
Davemurphy007's Avatar
Davemurphy007
Ford Focus Specialist
Flywheel (dual mass if using standard item), clutch, gear linkages and gear lever, driveshafts.
Not exactly a straight swap and the ST170 ratios aren't that well suited to the car either.
Old Feb 1, 2014 | 08:18 PM
MJ_RST's Avatar
MJ_RST
Why would you want to swap from the MTX75?
The getrag box ratios are rubbish for the focus.
Old Feb 6, 2014 | 08:36 PM
xr2imetalhead
my focus crunches into third gear and there was an st170 gearbox just up the road on ebay going cheap and was just gathering information really.
thanks chaps
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
mjonathan24
Oct 29, 2015 10:39 PM
Iain Mac
Sep 30, 2015 09:39 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
