Oil pressure and running temp in general. Info please.
Old Jan 26, 2014 | 08:31 PM
Rossy43's Avatar
Rossy43
Fiesta ZS. FF feat nov'11
Default Oil pressure and running temp in general. Info please.
Had an oil pressure and water temp gauge installed in the Cosworth.
Just after some guidelines on 'expected' oil pressures. Like cold, hot, kicking its head in etc?? And also what do you normally see Cosworths run at water temp wise?
Basically if I know ball part figures it makes the guages useful so I can see any changes. Thanks alot.
Old Jan 27, 2014 | 04:37 PM
Ridgey's Avatar
Ridgey
My own experience.
Oil (Mobil1 Motorsport) on std oil pump:
Cold running 70psi
Hot running 50psi
Hot idle 25-30psi
High pressure oil pump ADD 20psi to the running pressures
Old Jan 28, 2014 | 04:51 PM
nicksaph's Avatar
nicksaph
mines got very similar pressure readings as above but my cold running is 60psi.
that on castrol edge 10/50
water temp runs between 90 - 100deg
Old Jan 29, 2014 | 08:37 AM
Rossy43's Avatar
Rossy43
Very helpful boys. Thankyou. I use mobil 10-60 with standard stuff so this is ideal.
Chas
Sep 21, 2015 08:57 PM
mrmann
Aug 20, 2015 11:24 PM
Zoggon
Aug 10, 2015 10:39 AM
Roosie
Aug 9, 2015 07:37 AM
knight19770
Aug 4, 2015 12:36 PM
