Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
mk2 Focus 1.6 VCT non-start blows fuse 34.
Old Jan 25, 2014 | 01:44 PM
GVK.'s Avatar
GVK.
Default mk2 Focus 1.6 VCT non-start blows fuse 34.
Might be of help to someone searching in the future, been looking at a mk2 Focus (1.6 VCT sigma engine) that was recovered in non-start.
Initial diagnostic check had codes for primary circuits A & B on ignition coil, circuit faults on both intake & exhaust VCT solenoids.
Checked feeds to coil pack and VCT solenoids, no voltage on key on.
Checked wiring diagram and coil pack, injectors and VCT have feed from fuse 34 in battery junction box (underbonnet fuse box) checked 10a fuse blown.
Obviously dead short to ground on the green/white wire that feeds these components.
Didn't blow fuse straight away though, drove car for about 15 mins without an issue then it blew fuse the next time it was started!
Checked loom and eventually found chafing on the loom near block connector, that's near the starter motor, the insulation was rubbed through and could see where green/white wire had arced against one of the starter motor bolts.
Repaired wire and fault is solved.
Thought I'd mention it on here in case anyone's searching in future.
TPM961
Jan 15, 2018 10:50 AM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
gcfcos
88
Sep 15, 2015 03:48 PM
natehall
Sep 8, 2015 05:13 AM
