Help!! 2004 Mondeo 2.0 TDCI Gear Selector Problems
Old Jan 24, 2014 | 08:27 AM
Threaders15's Avatar
Threaders15
Default Help!! 2004 Mondeo 2.0 TDCI Gear Selector Problems
Good Morning
I have a manual 6 speed mondeo 2.0 TDCI estate which seems to be having problems getting into gear.
The clutch and DMF was replaced in August, and the car has done about 4k miles since.
For a while when the car was cold it was still a little stiff getting 1st gear, but other than that it was fine.
This morning my wife was driving to work and found that she could not select any gears a short distance from home.
Luckily she managed to get the thing back home - when I tried the gears with the engine off, there was no apparent noise or crunching etc - the clutch appears to have full range of movement and everything feels ok.
However when the engine is on it won't get into gear even when the clutch is pushed to the floor - when I took my foot off the clutch it felt like the revs dipped slightly.
I am obviously no expert here but it sounds like it could be a pedal problem rather than a clutch problem, but I would welcome the expert opinion before I call out the local ford dealer to look at it.
Old Jan 24, 2014 | 09:18 AM
Threaders15
I have checked the fluid and it seems ok.
There is no sign of any leakage under the car.
I can't select any gear with the engine on.
With the engine off everything seems ok.
I selected reverse with the engine off, kept the clutch pedal depressed and started the engine - when I released both the handbrake and footbrake the car moved backwards under its own steam (not gravity related btw) even with the clutch pedal as far to the floor as it will go.
It would appear to be in my laymans opinion something to do with the clutch not fully disengaging?
Your help is appreciated.
Old Jan 24, 2014 | 09:21 AM
oldford's Avatar
oldford
Yes, you're right. Clutch is not fully disengaging.
Old Jan 24, 2014 | 11:08 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Can you get it into gear if you repeatedly pump the clutch? Would suggest a hydraulic issue if you can.
Old Apr 30, 2016 | 05:44 PM
giordmaina@hotmail.co.uk's Avatar
Hi did you ever get this problem resolved? cheers
Jon
Originally Posted by Threaders15
Good Morning
Alun Gregory
Sep 6, 2015 09:40 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
