Alloy Vernier Camshaft Pulleys
Old Jan 23, 2014 | 05:32 AM
OZHCR32's Avatar
OZHCR32
Default Alloy Vernier Camshaft Pulleys
Have done a search but not able to find anything.
Anyway, my current Piper vernier camshaft pulleys are shagged with:
Inlet cam - 18thou run out
Exhaust pulley - 5thou run out
Visibly the inlet cam had a hell of a wobble...cams have come back ok. So looking at buying some Kent pulleys from Burton Power.
Question is, have people noted any increased wear from the alloy pulleys vs steel? Is that sort of wear/damage commong on high kms Piper Pulleys?
Its quite possible that they were 2nd hand jobbies used in the rebuild or just simp;ly damaged...just wondering if this is one of those things and that Piper are recognised as being better than Kent and should buy another set of Piper???Another brand???
Thoughts???
Old Jan 24, 2014 | 09:53 AM
Karl 3dr's Avatar
Karl 3dr
I've had adjustable Kent ones on one of my old engines with no problems, admittedly I didn't do many miles with them though. If I was to use some again though I think I'd go for the pegged Quaife ones though, firstly because there's supposed to be less chance of them slipping, and secondly because they look good lol
Old Jan 24, 2014 | 11:19 AM
James @ M Developments.'s Avatar
It is a common problem on the alloy pullies, i have piper ones on mine and there is certainly some wear on them,
We offer these,
http://www.shop.motorsport-developme...leys-863-p.asp
Which are hard anodised, which from what i have seen stops this from happening. I think i will be fitting some to mine.
The quaife ones are also very good, and they offer a steel version.
Old Jan 25, 2014 | 07:43 AM
BRAMMER's Avatar
BRAMMER
I've got quaife steel pulleys and they only cost about £130 delivered
Old Jan 25, 2014 | 07:52 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
All the well known brands of alloy pulley are hard anodised they do not last anywhere near as long as steel ones
Old Jan 25, 2014 | 08:20 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
You can buy hardened pulleys which will not wear as quick as normal alloy type ones that kent, piper, burton etc offer.
Old Jan 26, 2014 | 01:21 AM
OZHCR32's Avatar
OZHCR32
I grabbed some Kent ones for the time being. Will keep a eye on them and if need by may go the Quaife route
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
