Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Headlight bulbs blowing
Old Jan 20, 2014 | 11:26 AM
kjc300's Avatar
kjc300
Default Headlight bulbs blowing
My mate noticed both his dip beams weren't working, changed the bulbs after discovering both dip beam were blown.
Both new bulbs then blew within a few mins of each other.
Anyone had this before?
Old Jan 20, 2014 | 04:08 PM
kjc300's Avatar
kjc300
Up for teatime!!
Old Jan 20, 2014 | 04:27 PM
RichieST's Avatar
RichieST
Shit bulbs or touched the glass bit of the bulb with your fingers?
Old Jan 20, 2014 | 05:00 PM
GVK.'s Avatar
GVK.
Sure I've seen something for Focus where there are resistors available from Ford to stop frequent headlamp bulbs blowing.
What year Focus?
Old Jan 20, 2014 | 05:52 PM
m1ke's Avatar
m1ke
Mine was forever blowing bulbs as the voltage jumps to just under 17 when the heated screen was turned off. Tried all makes of bulbs and no difference until I used FORD bulbs. They were extortionately priced and not as bright as some of the others but have lasted almost a year so far...
Old Jan 20, 2014 | 08:39 PM
kjc300's Avatar
kjc300
2001 diesel.
Just the dip beam, both sides. Must be something common to both. Relay or alternator knackered maybe.
It has other gremlins too. Dash does funny stuff too sometimes.
Old Jan 20, 2014 | 08:48 PM
GVK.'s Avatar
GVK.
Could be a charging fault, needs checking out.
Resistor I mentioned is for the later 2004> Focus/Cmax/Kuga and 2008> Fiesta.
Old Jan 23, 2014 | 08:21 PM
kjc300's Avatar
kjc300
I can't find out anything about this resistor, do you mean alternator regulator?
Old Jan 23, 2014 | 09:17 PM
GVK.'s Avatar
GVK.
There's a Ford TSB about headlamp bulbs blowing frequently on 2004> (mk2) Focus/Cmax/Kuga and 2008> Fiesta.
There are resistors that plug into the headlamp.
It's not applicable to a mk1 Focus.
Nov 1, 2015 06:53 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
Flatlinedan
Sep 18, 2015 12:41 PM
