SOLVED!!! Chatter and no dump valve after fitting boost gauge....?
Old Jan 18, 2014 | 05:23 PM
Sierrasideways's Avatar
Sierrasideways
Default SOLVED!!! Chatter and no dump valve after fitting boost gauge....?
A little advice needed please...
Before fitting the Ford Racing boost gauge I had the usual pssssssssssshhhtttt from the dump valve when changing gears.
Fitted the boost gauge and tee'd it into the dump valve to inlet manifold hose.
Now I only have chatter and a little dump valve sound, chatter 1st, then DV.
The pssssssssssshhhtttt is gone......now it's chirpy as hell!!
Is this normal?.....or have I missed something?
Reading here, chatter can be bad?....i.e. Gas flowing back into turbo blades causing wear...
I'm running T34/.63, 500 cooler, GRP A cone filter, Bailey DV, etc etc
It was rolling roaded peaking at 26psi and holding 24psi (from memory) but the gauge is maxing out at 20 and holding 18.......driving it seems a little more restricted than before fitting it if that makes sense.....
Any advice is welcome.
Cheers,
Philip.
Old Jan 18, 2014 | 07:10 PM
Sierrasideways
Anyone at all.....is it normal?
Or is the chatter gonna wear the turbo....?
Old Jan 18, 2014 | 07:45 PM
Old ford's Avatar
Old ford
Pretty sure you shouldn't get chatter with a dump valve.
Old Jan 18, 2014 | 08:31 PM
Sierrasideways
Cheers for the reply Old Ford.
Chatter is coming from the air filter. No DV sound anymore.
Any ideas?
Old Jan 18, 2014 | 08:48 PM
KSA-Cossie's Avatar
KSA-Cossie
I do on mine
Old Jan 18, 2014 | 08:54 PM
frsjon's Avatar
frsjon
find another vac line for the gauge then it will be back to normal
Old Jan 18, 2014 | 09:03 PM
botters's Avatar
botters
competant bodger
try another vac line and see what that is like, chatter wont harm a t34 its only some of the gt series turbo's that dont like it. mine chattered and dumped on my cossie when i still had the dv fitted.
make sure you dont tee into the vacuum pipe for the fuel pressure regulator, that vac pipe should go to the fpr and nothing else
Old Jan 18, 2014 | 09:32 PM
costina's Avatar
costina
Live long and prosper!!
Glad you said that botters
Old Jan 18, 2014 | 10:16 PM
botters's Avatar
botters
competant bodger
thought i had better mention it ha ha
Old Jan 19, 2014 | 09:16 AM
Sierrasideways
The other easily available one is to the MAP sensor.....thought I read somewhere not to do this?
Thanks for the info. I know not to connect to the FPR pipe. The only other available one is blanked off and would need an adaptor to tee into it. It's the bottom vacuum connection on the inlet.
Old Jan 19, 2014 | 05:36 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
I think you might have what I done when I fitted my boost gauge. I plumbed in the t piece wrong and found that there was a little brass bit pressed into the t piece end that connected to the boost gauge pipe thus restricting the airflow to the dumpvalve causing the chatter. Hope this might help
Old Jan 19, 2014 | 06:44 PM
Sierrasideways
Kosienutter,
You've actually read my mind as this is what I was thinking. I had trouble locating a correctly sized t piece so had to make one up with various pieces....i.e. brass pieces, hydraulic pieces etc etc....crap I know
We squeezed the locking nuts very tight to ensure no leaks but I was thinking they could be oversqueezed and one of the olives could be squashed thus restricting the airflow to the dumpvalve causing the chatter, as you say.
I'll rip it tomorrow and double check it.
Much appreciated kosienutter
Will update this tomorrow.
Cheers,
Philip.
Old Jan 20, 2014 | 04:27 PM
BIL N KEL's Avatar
BIL N KEL
As you've said the boost pressure is down on what it was I'd say you have an air leak
Old Jan 21, 2014 | 09:07 AM
kosienutter
Cool bud. Hope it gets sorted.
Old Jan 21, 2014 | 09:19 PM
Sierrasideways
Default SOLVED!!!
Sorted now thank God.
Removed and checked all the olives on the t piece and all were actually ok.
Removed the elbow piece at the top of the DV and blew through it....very little air flowing through it....blew again and BOOM, this popped out
Drove it hard and have the DV back again.
Job done.
Old Jan 21, 2014 | 09:23 PM
kosienutter
Wonder what that is
Old Jan 21, 2014 | 09:24 PM
Sierrasideways
Weird I know but I think it's black insulation tape. Not a clue how it got there
Thanks for the help matey
Old Jan 23, 2014 | 06:46 PM
kosienutter
Happy driving
Old Jan 23, 2014 | 07:17 PM
Sierrasideways
Chas
Sep 21, 2015 08:57 PM
jay030787
Aug 17, 2015 06:16 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Churtz
15
Aug 13, 2015 06:40 PM
rsstav
Aug 11, 2015 04:22 AM
