T5 box sitting too high after Vibra technics
Old Jan 14, 2014 | 06:55 PM
L1AM_RS's Avatar
L1AM_RS
Default T5 box sitting too high after Vibra technics
I've recently fitted my Vibra technics gearbox mount to my 2wd saph, however it looks like the box is sat too high up as the 4 bolts at the gearstick side are touching the chassis ...
Can't really see how i've fitted it wrong as there wasn't much in the kit.
Has anyone fitted one of these before?
Old Jan 14, 2014 | 06:57 PM
Ade500's Avatar
Ade500
Fixing Fords
Yep I will see if I have a pic , but mine wasn't too high if anything it sat lower.
Old Jan 14, 2014 | 07:05 PM
Ade500's Avatar
Ade500
Fixing Fords
Ok here is a few pics, I noticed that the bolts for the box fouled the mount.
Both sides and it didn't pull up right so filed it for clearance. Then the mount actually touched the cradle so had to clearance that as well.
Again both sides.
No wonder people moan about vibration if they are all like this. Ps t5 in a 3door.
Hth
Old Jan 14, 2014 | 07:08 PM
L1AM_RS's Avatar
L1AM_RS
Thanks for the pictures mate.
I've fitted mine exactly the same. Might see if i can space it out somehow.
Old Jan 14, 2014 | 07:09 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
I fitted one to my Sapph and removed it straight away does not fit well very poorly made fitted a brand new standard one and feels awesome.
Old Jan 14, 2014 | 07:16 PM
L1AM_RS's Avatar
L1AM_RS
I bought directly brand new via a supplier and had a part missing to which they sent me one out asap, however thought the kit looks good, just strange having the gearbox sitting higher
Old Jan 14, 2014 | 07:30 PM
Tony Rs's Avatar
Tony Rs
Unless I chopped it around I wouldn't be able to fit it well and believe you shouldn't have to mess around with something like that so decided to fit a standard one instead.
Old Jan 14, 2014 | 07:32 PM
dojj's Avatar
dojj
Resident Wrestling Legend
are you sure its the right mount and not one for the 4wd box instead?
or is there only one? because they should list them separately shouldn't they?
Old Jan 14, 2014 | 07:49 PM
L1AM_RS's Avatar
L1AM_RS
Yeah deffinetly for the 2wd. I'll get some snaps tomorrow to show you.
Old Jan 14, 2014 | 11:26 PM
BRAMMER's Avatar
BRAMMER
I got mine cheap so decided to see for myself if they were bad and with Ade's little pointer i could clearly see where the vibration issues come from and modded mine the same and guess what nothing at all and feels really solid - my box doesn't sit any higher can't even think where you'd go wrong it's that simple
Old Jan 15, 2014 | 05:22 AM
MARCOSWORTH's Avatar
MARCOSWORTH
Have one on my saff and fits with no problems
Old Jan 15, 2014 | 07:52 AM
Ade's Avatar
Ade
Fast Ford snapper
That's pretty poor if they need that kind of attention to make them fit. Really deserve to be sent back, but I guess most people will just carry on and make it fit rather than have an extra week of the car in bits...
Old Jan 19, 2014 | 11:45 AM
L1AM_RS's Avatar
L1AM_RS
Old Jan 19, 2014 | 01:21 PM
dojj's Avatar
dojj
that does look a tad high yes
Old Jan 19, 2014 | 01:51 PM
ballbag42's Avatar
ballbag42
def high ? unusual never had probs with there parts before will have a look next weekend
Old Jan 20, 2014 | 04:20 PM
L1AM_RS's Avatar
L1AM_RS
If you wouldn't mind mate that'd be great
Old Jan 20, 2014 | 08:22 PM
Mungus's Avatar
Mungus
Very interesting post this....
Ive got god awful vibrations on mine and I dont think the box sits right either. Havent yet got underneath mine yet to check the mount and if its a modded one.... but im willing to bet its just like the above
Old Jan 21, 2014 | 05:35 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I must admit mine has a std mount and sits as high as that
Steve
Old Jan 28, 2014 | 03:56 PM
DaveCrack's Avatar
DaveCrack
Had to mod mine too as the 2WD box was sitting too high with the VibraTechnics mount and I'm still under the impression its too high...
Are there any other options besides going back to std?
Old Jan 28, 2014 | 09:09 PM
Ade500's Avatar
Ade500
Fixing Fords
A spacer or shim between the cradle and the shell.
Old Jan 28, 2014 | 10:17 PM
DaveCrack's Avatar
DaveCrack
Thanks mate. I guess thats the only solution. I have horrible vibrations from the gearbox and think that the mount is sitting too high is the reason.
Old Feb 4, 2014 | 11:59 AM
L1AM_RS's Avatar
L1AM_RS
Yeah i think this is what my only option is.
Surely they must of tested fitment before manufacture?
`spotty
Sep 25, 2015 11:41 PM
Cos500
Sep 15, 2015 06:47 PM
RSmark84
Sep 13, 2015 01:29 PM
Rizlablue
Sep 6, 2015 09:58 AM
Shows & Track Days
Sep 4, 2015 07:16 AM
