fiesta rs turbo OFAM HELP!!!
hi there, I am new to passion ford my name is carl.
I am thinking about buying an OFAM ecu from boostmonkeys.co.uk because at the moment i am running on standard ofac management and have read about the ofac to ofab conversion but to save me buying a new loom or trying to modify mine to ofab decided the ofam root made more sense..
anyway...my question is....would i need beige injectors or standard blues?
would i need an adjustable actuator or up rated fuel pump..
if any body runs one of these ecu's could you please tell me what i need not to kill the car.lol
cheers....carl
cheers....carl
whats the point in changing for nothing that different to what you have.
OFAC can still run a decent amount of boost and produce what you want anyway.
Different if you had an ERST and wanted to go efi.
You can buy a custom chip off stu@msd for couple hundred quid match to your spec with a set of bieges, cam and T3 turbo you would make just over 200bhp if the engine is in good health.
paceo
Feb 3, 2016 10:31 AM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
