anyone using a data stream? info please
Old Jan 12, 2014 | 09:25 PM
matthewpickup's Avatar
matthewpickup
Default anyone using a data stream? info please
I have been having a look at the data stream thing for £300 , so is anyone using this ? any good ? worth the money?
thanks for your time and help
Old Jan 18, 2014 | 09:41 PM
costina's Avatar
costina
Live long and prosper!!
Which one? secs ,RP labs iaw , Collins,
Old Jan 18, 2014 | 09:53 PM
matthewpickup
its the one matt lewis is selling
Old Jan 18, 2014 | 10:06 PM
costina's Avatar
costina
Link please
Old Jan 18, 2014 | 10:26 PM
matthewpickup
Originally Posted by costina
Link please
http://www.mattlewismotorsportonline..._10939866.aspx
Old Jan 18, 2014 | 10:31 PM
costina's Avatar
costina
They are good its just a revised secs version. ive the secs one which gives all the info you require.
It would be even better if it had wideband on it too tho
Old Jan 18, 2014 | 10:45 PM
fraser9764's Avatar
fraser9764
nearly ordered one myself, but was put of by the fact there are two different versions for wasted spark and dizzy setups. so if i upgrade to WS in the future i have to sell and buy another.
surely it would have made sense to have it configurable, its only a divide/multiply the rpm reading by 2 at the end of the day.
extra inputs for oil pressure and wideband would be good too.
Old Jan 18, 2014 | 10:50 PM
matthewpickup
yea I will be running WS but what the put off for me is theres no air/fuel and oil pressure which I think are rather important so thing I may just stick with the gauges for now unless it changes in the future
thanks for your help
Old Jan 19, 2014 | 12:09 AM
James @ M Developments.'s Avatar
If they wire up like the secs monitor then they don't really stream any data from the ecu at all, they wire into the engine loom and tell you what it thinks the ecu is seeing.
The only way to actually see what the ecu is seeing is to stream data from the diagnostic port via pins 8-11-27
Good product though I always liked my secs monitor
Old Jan 20, 2014 | 12:59 PM
martysmartie's Avatar
martysmartie
As above, it's merely a voltmeter!
Also remember for a data stream, you need to factor in a price for a data stream enabled chip, which yours probably isn't!
Martin
Old Jan 20, 2014 | 06:23 PM
grcossie's Avatar
grcossie
I have a collins monitor in the shelf, what do i have to modify, to get data stream from my p8?
Old Jan 20, 2014 | 07:13 PM
costina's Avatar
costina
Think you have to use a Collins chip for it to work
Old Jan 20, 2014 | 08:40 PM
martysmartie
Are you sure, I would have thought anyone's software with DS enabled will work?
The 'Collins' chip will be nothing special, essentially all remaps are just modifications of the original software.
Martin
Old Jan 25, 2014 | 03:17 PM
grcossie's Avatar
grcossie
I now you can use it on other than Collins chip as long as it`s have possibility for reading data streams, but you have to modify p8 somehow to open this, thats what i`m looking for
Old Jan 27, 2014 | 08:46 PM
martysmartie
It's not a hardware thing I shouldn't think, rather the software has to have a DS enabled.
Martin
Old Jan 31, 2014 | 08:36 AM
RS Bowk's Avatar
RS Bowk
That is incorrect. If you change ignition type then you can simply send your monitor back to have the necessary modification to make it suitable for your new ignition. Appolgies if you have been misled on this.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Mc5506
Sep 29, 2015 09:06 AM
