St205 gt4 decat needed asap
How can it be easier than just dropping the guts out of the one you have ? and had apart, 2 minute job tops ?
Or is yours a solid downpipe with the cat inside ? not bolted together ?
Because there is 18 fiddly bolts to refit cat and a pain they are to fit , also there is the hangers either side of the cat that bolts to the block with 3 bolts each side
Right cunt of a job!
With a de cat it is just bolts to exhaust housing and to exhaust - (9 bolts) easy to fit
borboyous
Aug 22, 2015 11:17 AM
blakey100
Aug 4, 2015 08:17 PM
