sapphire 2wd rear arb
Old Jan 7, 2014 | 02:26 PM
john-saff's Avatar
john-saff
Default sapphire 2wd rear arb
i have a 2.0 dohc sierra at the minute and noticed it has no rear anti-rollbar and cosworths do , i done a bit of research on here am i right in saying an escort cosworth rear arb is a straight fit into the back of a sapphire all i will need to do is get 22mm arb bushes and drop links and weld some brackets onto my swing arms to attach the roll bar drop links to ? thanks
Old Jan 7, 2014 | 09:21 PM
105epwr's Avatar
105epwr
Yes, I took my std sapp 16mm roll bar out and put a escort 22mm in with the mounting brackets....but tbh it didn't make a huge difference between 16mm and 22mm
Old Jan 11, 2014 | 02:13 PM
john-saff's Avatar
john-saff
and was it a straight fit ? what drop links did you use sierra ones ?
Old Jan 11, 2014 | 04:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the roll bars are direct swaps, you just need to change the bushes that hold the bars in place
they came i 14, 16, 18mm on the sierra and 22mm on the escos
when i bolted the escos one to mine it became immediately much more tail happy on the limit but gave much better grip until that moment it snapped out and was fairly uncontrollable when it did tail out
there was a fairly comprehensive thread here a few years ago about tail happiness induced rear arb settings
Old Jan 11, 2014 | 07:07 PM
john-saff's Avatar
john-saff
cheers dojj i think an escort cosworth one will do perfect
Oct 9, 2015 07:38 PM
mint_s2
Sep 2, 2015 08:58 AM
FlashRS
13
Aug 31, 2015 06:02 PM
saph in dorset
Aug 14, 2015 10:10 AM
Old ford
Jul 31, 2015 06:50 AM
