flashing glow plug
Old Jan 6, 2014 | 01:10 PM
bish86's Avatar
bish86
Default flashing glow plug
Hi
I have a mondeo mk3 Tdci 2.0 130 04 plate after a 600 mile drive home with no problems the next morning started the car drove approx. 30miles accelerated hard up a hill in 5th glow plug flashed and engine cut out rolled to a stop and car started again no problem set off again 20mile down the road same problem the problem has been going on for weeks now,changed cam sensor drove at 4000rpm 2nd gear no problem changed into top gear to cruise home engine cut out symtoms are engine shudders if I push clutch quick engine continues to run,always starts no problem,i have cleaned the maf sensor, manifold ,egr valve and blanked it off no different turbo actuator functions ok
has anybody got any suggestions please
thanks
Old Jan 6, 2014 | 02:32 PM
daviddunlop83's Avatar
daviddunlop83
Have you had the fault codes read?
Buy the likes of F Super from ebay for £20, its brilliant for reading the codes and can also programme injectors.
My mechanics snap on reader couldn't see the EGR fault code on mine, F super showed it straight away
Old Jan 8, 2014 | 01:27 PM
bish86's Avatar
bish86
Hi
Thank you for replying to my post,i am waiting for the code reader to arrive so will keep you posted
Old Jan 9, 2014 | 05:32 PM
leep27's Avatar
leep27
Mine did the same. It was the injectors. Did a leak off test. Injectors 3&4 were leaking buckets. Ended up being a bugger to start as the rail pressure won't build up. Found a guy on eBay who reconed them for £114 each and a 3 day turn around. Been spot on since. eBay item No. 161112898724
Old Jan 21, 2014 | 08:02 PM
bish86's Avatar
bish86
Sorry for slow response just bought my second code reader which is the f-super like suggested and this is not compatible with my car anybody got any suggestions please (can't afford many more)
Old Jan 21, 2014 | 08:07 PM
daviddunlop83
In what way isn't it compatible?
Old Jan 21, 2014 | 08:11 PM
leep27's Avatar
leep27
F-super should work. It's what I got for mine. I have a 53 2004 TDCI and it works for the PCM the injectors and airbags. All tho for some reason won't work the abs. Any how I can trace and delete dtc's gives codes and a vague description. I can even enter injector codes. I found the software a chew on to install into my laptop. Maybe you've not installed the software correctly!
Old Jan 21, 2014 | 08:14 PM
daviddunlop83
Or do you mean it doesn't list your exact car? It doesn't list 2.2 Mondeo but I just went into diesel Mondeo and it works fine
Old Jan 22, 2014 | 08:27 AM
bish86's Avatar
bish86
I bought obd11 reader screen lights up but does not show anything, told it was probably the wrong code reader I was advised to buy the f-super after waiting weeks for it to arrive and lots of problems installing the software plugged it into the car and it says connection failed turn key on ,when I turn the key it just repeats the message short of setting fire to the car I don't know what to do next,
Old Jan 22, 2014 | 09:00 AM
leep27's Avatar
leep27
It will defo work for your car. It sounds yo me like the software hasn't been installed correctly. Failing that a faulty unit. I had hassle installing the software. You have to nominate a comm port and select it when you run the formidable app. The disc I had showed me how to do it via a short video.
Old Jan 22, 2014 | 09:14 AM
oldford's Avatar
oldford
A EOBD/OBD2 code reader should work on a 2004 diesel.
Does this code reader work on other (EOBD compliant) cars?
When yes, check wiring in your vehicle. When no, the unit was defective.
Old Jan 22, 2014 | 11:37 AM
daviddunlop83
I vaguely remember having issues with ports tho it was a couple of years ago I installed it in a laptop.
If the correct port isn't selected then it will def show the connection error.
Old Jan 22, 2014 | 11:51 AM
leep27's Avatar
leep27
Think you have to go into the device management and find a free comm port. Between certain numbers. Then when you run formidable select the said port and it comes up with a list of cars. Think first time you do that it never a asks for a port again. Bit of a faff but once it's working it's usually pretty good for what it is and costs.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
