Mondeo mk3 tdci buying advice
Hi!
I've been looking into buying a Mondeo MK3 diesel,pretty much decided to buy a estate, but I cannot decide between chosing a tddi or a tdci model. So far, what I've read about them is that the tddi is much more bulletproof than the tdci(injectors problems mainly). Whay do you think about this?
Another question is, I can buy a 2006 tdci model for the same price as a 2002 here in my country (they are very devalued).Were the tdci problems fixed by Ford by then or are they the same as in the first models?
Another Q, it is better to buy a car with around 80k (miles) that it maybe have not had replaced injectors or clutch , or one around 125k (miles), with more things changed in its life?
Thanks a lot!!
Thanks a lot!!
I was looking at buying a TDCI Mk 3 Mondeo estate but went for a 2.0 petrol instead. The whole Diesel injector and fuel pump issues put me off. The injectors are about Ł200 each and have to have the ECU reprogrammed when they are changed so it's not something you can do yourself. Not sure if it's the same with the fuel pump but they are a grand. Seems they often all pack up at the same time. There do seem to be a few on ebay with management light on and it wouldn't be worth spending that sort of money to fix them.
Thanks for the opinions! I think I will wait till I find a correct TDDI unit! The DMF does not bother me too much, but the start up and running problems that can have the tdci really puts me off too...
As with any car there is always horror stories.
If you get a later one, after mid 05 most of the injector issues were sorted by then and they don't have any more common injector problems than any other modern diesel.
The pump doesn't need coded tho doesn't go that often. As for the injectors you can code them yourself with F super which costs Ł20 and can be used for fault codes too.
My ST tdci had 113000 on it now and I changed the flywheel at around 100k.
Only other issue I have had with it is the pin sheering off the EGR valve, but 80p fixed it with a bit of silver steel dowel rod.
I used to have a tddi with 170k on it and was still fine, bit noisey but ran fine. I know my G/F's uncle bought a tddi from new and used it as a taxi up to 460,000 miles and pnly put a couple of clutches in it and replaced the electronic pump which is under car which is only Ł100 (failed on my one too at 120k) apparently its common to fail around 100k
Thanks daviddunlop83!
Yes I know all modern diesels can suffer this failures(I am tech at Volvo dealer, I deal with this things everyday!). That's why I would prefer something more forgettable like an older tech TD .
It's a 2002 car, it cannot be THAT noisy. I'm used to driving older cars daily,so I'm sure it will be fine for me.
These are very devalued at the monent and I think they offer a lot of car for the money.
After hearing your experience with the tddi, I will definitely go for one. Will post pictures!!
Basically buying ANY second hand car is a lottery, and buying a second hand diesel is more likely to be costly (when it breaks) than the equivalent petrol engine.
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
