Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
fuel lines
Old Jan 3, 2014 | 10:24 AM
timsrs's Avatar
timsrs
Default fuel lines
Starting to do fuel lines on my car..
i was thinking of using solid to run the length with braided at either end...
What do you use for the solid pipe i have heard of stuff called cunnifer or something like that..
Also is there a compression fitting so i can run braided from the solid pipe.
Tim
Old Jan 3, 2014 | 05:08 PM
jamie956's Avatar
jamie956
Tim
Depends what engine your running and the amount of fuel required, all so if a low or high pressure system, if its just a carb'ed v6 or smaller I would just use copper pipe with a jubilee clipped hose each end.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
Dubs44
Sep 19, 2015 06:31 AM
