SECS fitting instructions
BLACK > ECU PIN 1: GROUND
RED > ECU PIN 20: 12V POSITIVE SUPPLY
GREY > ECU PIN 25: IGNITION SIGNAL FOR RPM READING
GREEN > ECU PIN 17: THROTTLE POSITION SENSOR
BLUE > ECU PIN 29: ENGINE COOLANT TEMPERATURE SENSOR
YELLOW > ECU PIN 31: AIR CHARGE TEMPERATURE SENSOR
WHITE > ECU PIN 15: MAP SENSOR
Rich
Rich
Rich
Rich
Whats the recommeded way to attach these wires as you describe without comrimising the feed to the ECU?
Huw
Rich
Daisychain
Aug 22, 2015 08:12 PM
