Help needed for 3dr
Old Mar 23, 2005 | 05:51 PM
ImaRacing 700's Avatar
ImaRacing 700
Default Help needed for 3dr
I noticed the steering was a bit vague so investigated and found that where the steering rod joins on to the steering rack there is a rubber bush and its perished on one side..obviously the problem...but how do i change it??.........
TIFF's Avatar
TIFF
Chasing Radders
Look out Steve, Phil is coming for you
Old Mar 23, 2005 | 05:53 PM
ADUSR33's Avatar
ADUSR33
heres a idea set it on fire and buy yourself a decent car u moron
Old Mar 23, 2005 | 06:24 PM
ImaRacing 700
I take it i am being treated like a newbie by lack of replies from non homos
Tiff a car is bought sold as seen....plus its nearly 20 years old...i expect a few worn bits
Old Mar 23, 2005 | 06:26 PM
TIFF's Avatar
TIFF
Chasing Radders
Newbie
Old Mar 23, 2005 | 06:27 PM
Ryan's Avatar
Ryan
not a easy job, the steering coloum needs to come out i think.
you need to undo the pinch bolt holding the coloum to the bush then the 3 or 4 m8 bolts which hold the bush to the rack.
think thats right.
Been a while since i've looked
Old Mar 23, 2005 | 06:44 PM
Tony Ryan's Avatar
Tony Ryan
Need to grind the rivets out if you intend changing it , i understand Powerflex now do an uprated version of the std rubber shit thing as a direct replacement .
Old Mar 23, 2005 | 06:53 PM
900ss's Avatar
900ss
RWD Racer
Just change the whole lower coupling?
Dont think they are meant to be rebuildable as such.
2 bolts is it not? 10 or a 13mm spanner I believe?
Remove the upper bolt n swing the clamp out the way
The coupling should then just slid up n off the splined shaft.
I think
Old Mar 23, 2005 | 08:17 PM
SPADGE's Avatar
SPADGE
As Wyn said just change the coupling Phil!
These are available from Ford circa 75 quid
Old Mar 23, 2005 | 08:23 PM
PMSL @ newbie......
DIY NEWBIE who aint a DIY really cause he can't figure fuck all out for himself
Old Mar 23, 2005 | 10:41 PM
ImaRacing 700
Dingy,anyone thats runs a grey with the undrilled cap.....cannot comment on my threads!!!!
Cheers for the advice everyone else
Old Mar 23, 2005 | 11:15 PM
CozzyBrom's Avatar
CozzyBrom
immy belave it or not a vw bettle one fits
£12 for euro car parts
Old Mar 23, 2005 | 11:25 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
BROM@ZOO, Now you could believe that, and get it cheep as chips and pat brom on the back, OR you could take it as someone who wants you off the road/forum fast
Old Mar 23, 2005 | 11:34 PM
R4N SS's Avatar
R4N SS
that is cheap -
brom u wouldnt happen to know the part no. would u?
Old Mar 23, 2005 | 11:37 PM
CozzyBrom's Avatar
CozzyBrom
i can get u one if u want
am sure some where down the line i owe u some cash
lol
Old Mar 23, 2005 | 11:39 PM
CozzyBrom's Avatar
CozzyBrom
no its true
i work on hunderd of scrap beetles in my welding restoring days
they fit
Old Mar 23, 2005 | 11:43 PM
CozzyBrom's Avatar
CozzyBrom
http://www.eurocarparts.com/ecommerc...ch_Results.asp
i was wrong £4.75
Old Mar 23, 2005 | 11:45 PM
Stu.H's Avatar
Stu.H
wont be a true RS then tho
Old Mar 23, 2005 | 11:47 PM
R4N SS's Avatar
R4N SS
no probs Brom - will check to se if I actually need it first - cossie is booked in next week for a few bits so can get it checked then - appreciate the offer
Or there is always a pint you could shout at Central Day unless I decide to bring my cooler box full of Stella again then the drink is on me
Old Mar 23, 2005 | 11:56 PM
CozzyBrom's Avatar
CozzyBrom
stella cool man
bring it ova and grab a seat am sure we can share
CLIVE
Oct 2, 2015 12:58 PM
billybob
62
Aug 25, 2015 07:21 AM
IAN RS2k
Aug 18, 2015 07:51 PM
col93saphcos
Aug 7, 2015 03:21 PM
paceo
12
Aug 4, 2015 08:50 PM
