Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
wet fiesta boot, where's the water coming from?
Old Dec 29, 2013 | 02:48 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default wet fiesta boot, where's the water coming from?
It would appear to be coming from the boot seal as its all gunky but how is it getting in?
Can it get in from somewhere else?
Can I get a replacement?
Etc?
Old Dec 29, 2013 | 03:05 PM
Rear light seals???
Old Dec 29, 2013 | 03:10 PM
costina's Avatar
costina
Live long and prosper!!
Sunroof drain tubes blocked( if it has one)
Roof aerial ?
Old Dec 29, 2013 | 03:32 PM
Mk4 Rick's Avatar
Mk4 Rick
Sit someone in the boot and get the hose pipe on it .As Glenn said above rear light seals are a suspect and the boot seal.
Old Dec 29, 2013 | 03:55 PM
STeve's Avatar
Super Moderator
if its a mk5 then its common for water to get in through the rear wiper grommet, easy to tell as sometimes if you lift up the tailgate and water comes out the drain hole dead centre near latch other than that the lads advice is next place I would look and boot seals and light gaskets are still available from ford
Old Dec 29, 2013 | 03:56 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Rear light seals are common too IIRC. mk4/5's were prone to it.
Old Dec 29, 2013 | 05:16 PM
dojj's Avatar
dojj
cheers guys
the boot floor is soaking wet, but the lights on both sides are bone dry, so dry in fact that there are spiders living behind the carpeting
Old Jan 5, 2014 | 01:18 PM
dojj's Avatar
dojj
Its coming from the window seal
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
David Potasnick
Ford Fiesta
Aug 22, 2015 10:54 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Dazts1
Was It You?
Aug 2, 2015 06:44 PM
