Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Mk 6 Fiesta front passenger side window
Old Dec 27, 2013 | 09:07 PM
blackbess14's Avatar
blackbess14
Default Mk 6 Fiesta front passenger side window
Can anyone help.The front passenger window on my Mk 6,4 door Fiesta Zetec has stopped winding up or down.The motor appears to be working but the window is stuck in a partially open position. I can push it down but can not push it all the way up. I've managed to get the door panel off,removed all the 10mm bolts that hold the whole assembly on but as the window is not fully up,the two 10mm nuts that hold the glass to the assembly, do not line up with the holes which are revealed by removing the two sticky-backed covers.Any ideas what might be causing the window not to be lifted up all the way to enable me to align the two holes up with the two 10mm nuts? Sorry if it's such a long thread but any help would be greatly appreciated.
Last edited by blackbess14; Dec 27, 2013 at 09:09 PM. Reason: left some wording out
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
