Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
mk5 fiesta zetec s eml light
Old Dec 27, 2013 | 05:09 PM
sheldonzetecs88's Avatar
sheldonzetecs88
Default mk5 fiesta zetec s eml light
hi
ive got a mk5 zetec s and the eml light has come on,just looking for any ideas what it could be.
ive recently had the timming belt n clutch done but to me it seems not as quick as it use to be.
be very greatful for some1 to point me in the right direction
Old Dec 27, 2013 | 05:15 PM
studabear's Avatar
studabear
It could be many things, it needs the fault codes reading.
Old Dec 28, 2013 | 09:04 PM
Lambda sensor???
Old Dec 28, 2013 | 09:38 PM
Mk4 Rick's Avatar
Mk4 Rick
Originally Posted by Glenn_
Lambda sensor???
I would guess the Lamda as well lol depending on the mileage or what shit fuel was used.
Old Dec 28, 2013 | 09:49 PM
GVK.'s Avatar
GVK.
If the cam belt has just been done, now it's not as quick, it could be because the cam>crank timing is off, and it's putting a timing correlation error in?
You could unplug the lambda and not know any difference by driving it, other than it using a tad more fuel!!
All guess work, it needs the codes checking, by someone who understands what they're looking at.
Old Dec 28, 2013 | 09:55 PM
Mk4 Rick's Avatar
Mk4 Rick
You are right ive just thought about it lol.If the lamda was fucked it would more or less drive the same just burn more fuel
Old Dec 28, 2013 | 09:57 PM
Lambda was worth a guess lol.
Old Dec 28, 2013 | 10:35 PM
GVK.'s Avatar
GVK.
Lambda (narrow band) only works during idle and light cruise situations (once the sensor is warmed up!), on full throttle, lambda feedback is ignored by PCM.
You pair should know that!
Old Dec 29, 2013 | 07:25 AM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Cat might be blocked up too...that brings EML up on these and could be a cause of feeling sluggish!
Old Dec 30, 2013 | 09:36 AM
sheldonzetecs88
ok thanks guys.so if my cat is blocked can I just put a de cat pipe.any1 in the London area got a faultcode reader.
JoeyBoyden
Jan 4, 2024 02:36 PM
Ethan sagoo
Aug 25, 2015 03:22 PM
jaysoc1
Aug 20, 2015 08:18 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
