mk2 focus rs missfire
Old Dec 11, 2013 | 06:06 PM
cossieboy599's Avatar
cossieboy599
Default mk2 focus rs missfire
my mk 2 rs has a couple of times randomly dropped a cylinder for a fue seconds then its absolutely fine anyone else had any problems ??
Old Dec 11, 2013 | 06:21 PM
NEIL A's Avatar
NEIL A
I have seen a few need a new coil on plug , if you have a code reader check for saved codes
, also worth checking plug gaps if it is running more boost than standard.
Old Dec 11, 2013 | 06:22 PM
cossieboy599
no the engine is totally standard ill try get it to mates get it scanned
Old Dec 11, 2013 | 06:58 PM
bobbob's Avatar
bobbob
Might be a coil pack as I've had one on mine already. But silly question is it could be the traction control cutting in. Also when they are very cold they seem a bit flat.
TPM961
Jan 15, 2018 10:50 AM
richierich1986
Sep 18, 2015 03:29 PM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
