Ford Fiesta Style 2005 1.25
Old Dec 7, 2013 | 05:08 PM
FlightSim's Avatar
FlightSim
Default Ford Fiesta Style 2005 1.25
Hi I'm trying to repair my girlfriends fiesta style 2005 1.25 . I'm fairly certain the thrust bearings gone when the clutch pedal is depressed the clutch plate rattles. To take the gearbox off do I need to undo the main engine mount to be able to tilt the gearbox enough to take it off. Should I take the subframe completely off to allow enough space to take the box off, or can I just undo the four main subframe bolts and pull it to one side instead of having to undo the steering rack hoses. thanks Paul
Botts
Aug 13, 2015 04:16 PM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
creator
Aug 2, 2015 12:24 PM
