Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Mk3 Cortina 24v Cosworth Conversion advice
Old Nov 28, 2013 | 10:51 AM
Jumpinjacks's Avatar
Jumpinjacks
Default Mk3 Cortina 24v Cosworth Conversion advice
I've got a mk3 Cortina 1600L that currently has a 2 litre pinto and type 9 box.
I am considering buying a whole scorpio Cosworth and putting that engine in, I know the type 9 ideally would need upgrading to a mt75 hybrid box, but is there anything else to consider?
What prop shaft do I need?
Will the standard diff and rear axle need upgrading?
Do the brakes and suspension need upgrading? It currently has discs front and drums to the rear, its also been upgraded with a servo.
Will everything I need apart from the box be on the scorpio?
Has anyone done this conversion in this car, if so what problems did you come against?
I've done a search on here, but most of the cars its been done to are Capris.
Any advice would be much appreciated.
Old Nov 28, 2013 | 10:56 PM
mk22door's Avatar
mk22door
Fart of the Purniture
If you were going to use a type 9 box it'd need to be for a six pot, the one mated to your pinto will be no good anyhow, so may as well get sorted with a propper MT75 hybrid box.
Best get yourself onto the ford power forum mate, loads of info on there.
Old Nov 28, 2013 | 11:20 PM
Jumpinjacks
Yeah I've read that. I've found one for sale online by a gearbox company, already done built with new internals for £425 delivered and has 12 months warranty. So would probably go for that.
I'll have a look on Ford power aswell. Cheers.
mk3 fiesta cosworth
Aug 23, 2015 10:31 AM
Sultzi
12
Aug 16, 2015 01:08 PM
Aug 14, 2015 07:29 AM
