4x4 Gearbox and clutch options
Old Nov 23, 2013 | 10:49 AM
KW-rscos's Avatar
KW-rscos
Default 4x4 Gearbox and clutch options
What options are there for around 450bhp without spending silly money? Made a plate for the front diff and looking at 7.5 rear beam an diff for the back, but what about the gearbox/clutch?
Regards, Kieren
Old Nov 26, 2013 | 07:53 AM
carl/saff's Avatar
carl/saff
SIERRA RS 4X4 COSWORTH
I would use a AP organic at that power......
Depends how much grief you give the clutch .... i will use a HD plate when the time comes..
Old Nov 26, 2013 | 11:47 AM
Paul_RS's Avatar
Paul_RS
Ap 6 paddle and some form of straight cut box is what you'll need to remain reliable.
Old Nov 26, 2013 | 08:52 PM
Caddyshack's Avatar
Caddyshack
Would a big tooth box with helical gears be up to it? Bara seemed to have a few different options.
I am gonna need a better box soon but dont think I want the wine of a straight cut box
Old Nov 27, 2013 | 03:45 PM
charlie luciano's Avatar
charlie luciano
The cheapest big tooth kit on the market for a 4x4 is the oppliger kit which is around £1950 for the gear kit, you then have to get that fitted into your casing, if you don't DIY it, it will be a few more hundred quid to get someone to do it for you, if you don't run into any unforseen problems whilst building the box you're looking around £2600 all done, 6 paddle AP clutch is the way to go if you're looking for big pony power but they are a bit shitty, they are either on or off, there's no inbetween
Luciano
Old Nov 27, 2013 | 06:10 PM
Caddyshack's Avatar
Caddyshack
Luciano
Thanks, really useful info....looks like the plan is vipec, Borg Warner twin scroll then big tooth.....I bet it will need diffs then!
Old Nov 27, 2013 | 06:16 PM
MrC's Avatar
MrC
Isn't it around £1k per diff??
Old Nov 27, 2013 | 07:05 PM
Caddyshack's Avatar
Caddyshack
I think quaiffe may be more fitted? £1000 each sounds fair if it doesn't break.
Just rebuilding the drive shafts ready. Might go supra diff if can match to the front one.
yatta
May 21, 2016 10:31 PM
Escortdriver1
Sep 6, 2015 10:12 AM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
cossirob
Sep 3, 2015 09:17 PM
