Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
How do i cut my mk1 firewall to fit my yb cosworth??
Old Nov 22, 2013 | 12:06 AM
FATMK1's Avatar
FATMK1
MK1 MEXICO YBT COSWORTH
Default How do i cut my mk1 firewall to fit my yb cosworth??
Hi all is it necessary to cut the firewall in my mk1 escort so my cossie will fit?.... If there is no way around cutting, then how do I start...ie..measurments etc?....I got an auto tunnel from a donor car, but really dont want to stuff this one up, so does anyone have pix of what they have done to there mk1 early mk2?...preferably an original auto tunnel, not on of those aftermarket squared off ones....any help is much appreciated....thanks
Old Dec 4, 2013 | 05:01 PM
BigBubba's Avatar
BigBubba
Old Skool Nutter
Not sure about the mk1, but you can trim the rain gutter back on the mk2.
Pretty straightforward job, plenty of guys done it, so there should be plenty of info on the old tinternet.
Old Dec 30, 2013 | 10:10 PM
andym's Avatar
andym
Not sure about the auto tunnel but if you trim the seam on the edge of the heater bubble you will have enough room for the YB.
Old Dec 30, 2013 | 10:31 PM
dingla rs's Avatar
dingla rs
just need trim the edge off auto tunnel is bigger than the ones you buy pal
Old Dec 31, 2013 | 12:12 AM
FATMK1's Avatar
FATMK1
Thanks heaps dingla rs....if I don't cut the firewall, how close does the engine sit to the original firewall?...I've only seen mk1s with cut firewalls so I'm not to sure, are we talking millimetre?....I have an auto tunnel.... what do you mean by trim the edge off the tunnel?....at the front of it where it meets the firewall?
Old Jan 6, 2014 | 09:33 PM
soft spot for mk2 escorts's Avatar
when you trim across the top of the bulk head remember that this is a joint seam that holds the top heater panel to the bulk head, when you remove this you will need to run a weld across the now weakened area and tidy it up with a grinder, if you don't it will separate and leave a gap between the two and will let rain water into the car and split across the front.
Old Jan 9, 2014 | 07:08 PM
Caddyshack's Avatar
Caddyshack
You can buy pre-prepared tunnels can't you? Or is that mk2 only?
Old Apr 3, 2014 | 05:43 AM
john_3.0s's Avatar
john_3.0s
Put a post up on oldskoolford there are plenty who have done it on there
john_3.0s
Aug 15, 2015 07:44 AM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
