Removing ignition barrel without keys?
Old Nov 16, 2013 | 09:12 PM
wattie's Avatar
wattie
Default Removing ignition barrel without keys?
My mate has been keeping his saff in one of our units as he's offshore a lot and doesn't like leaving it outside his house , all was well until last Friday some little fucktards smashed fuck out the fire exits and stole 3 push bikes (2 shit ones and my brothers 2k cannondale) and they smashed open the key press and took all our car keys , tried to steal a Chrysler voyager we were doing a homer on but they couldn't get it started , so , the only set of keys for my mates saff are gone along with the alarm fob and imobaliser stick , he's got a new lock set so door locks got done today but he's having trouble removing the ignition barrel , is there a trick to doing it, or can you go to ford and get a key made to that barrel so it'll come out so he can swap them over , I never had a chance to help him as I was doing a homer all day but going to have a go tomorrow , any tips of removing the barrel with out damaging the steering column?
Old Nov 16, 2013 | 09:27 PM
boy-racer-1's Avatar
boy-racer-1
screwdriver in twist and hope for the best or try a ford tibbe pick bit expensive though just to get a barrel out
Old Nov 16, 2013 | 09:28 PM
paulsheerin's Avatar
paulsheerin
Mate you could be lucky, with the chassis number of the car Ford should be able to give you the Tibbe number for the key or cut you one there and then.
That way you could get the barrel out and replace it so the tea-leaves wont get it
Old Nov 16, 2013 | 09:44 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Remove the cowling and you should see a small metal join which drops down to remove the barrel
If push comes to shove you can remove the steering wheel and bust the steering lock pin and then removing the entire top portion of the lock assembly
You can still pick them up complete and that may be the easiest solution if you can't get the lick out and bugger the barrel assembly
Old Nov 16, 2013 | 10:29 PM
cossiestu's Avatar
cossiestu
Take one of the old barrels apart to get the old key number, cut a key to get the ignition barrel out....
Old Nov 16, 2013 | 10:40 PM
GVK.'s Avatar
GVK.
Genius!
Old Nov 17, 2013 | 11:22 AM
wattie's Avatar
wattie
Yeah seems like the best option , the boot key was different to the rest of the car when he got it so not sure if the locks have been changed before but aye both front doors were the same as the ignition so get number off them and get key cut , cheers lads
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
jay030787
Sep 18, 2015 04:38 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
hopper350
Sep 4, 2015 12:53 AM
