Ford Puma Discuss the Ford Puma here!
Tinkered with my Puma today updated 12/02/14
Old Nov 16, 2013 | 04:51 PM
Default Tinkered with my Puma today updated 12/02/14
Had a play about with the Pooma today.I was gonna have a go fitting a cone filter but I didnt have any spare pipe to fit over the air flow meter. So I modded my standard air intake so its getting a cold feed from the front of the front bumper.
I turned the pipe around so that it is facing the front. The gaffer tape is to make sure its got a good seal.
Then I cut the rubber splitter where the holes are in the front bumper.
I cut the other side out too.Before
After
Anyone know what this is. Is it the resonator and whats it do.
Thought I would try my Momo arrows on the Pooma.
Then gave her a wash.
Old Nov 16, 2013 | 05:12 PM
STeve's Avatar
Super Moderator
when I serviced my puma last week I was fart arsing around with cold air feeds then decided it ran fine as it was so left it as is, I ended up fitting a more beefy horn when I was in that area too Glenn
Old Nov 16, 2013 | 06:29 PM
Its got a bit of induction raww now toooo.
Old Nov 16, 2013 | 06:35 PM
TOOTALL's Avatar
TOOTALL
I reckon they suit the Puma down to the ground.
Old Nov 16, 2013 | 07:29 PM
RSBryden's Avatar
RSBryden
10 Year Member
Clean puma mate
Old Nov 16, 2013 | 08:17 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Glenn!!! The arrows look awesome mate
Old Nov 16, 2013 | 09:28 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Yeaaaah those Arrows look ace!
Old Nov 16, 2013 | 09:45 PM
RichieST's Avatar
RichieST
The arrows look smart on it glenn, you keeping them on there?
Old Nov 16, 2013 | 10:09 PM
Yeh I think they suit it as well. Na im not keeping them on. I should try it some day and see what it drives like with them on.
Old Feb 10, 2014 | 05:23 PM
bagginsRSturbo's Avatar
bagginsRSturbo
Take the resonator out Glenn it's what I did on mine
Old Feb 11, 2014 | 06:10 PM
Ive heard on project puma that this makes no difference.
Old Feb 11, 2014 | 06:20 PM
bagginsRSturbo
I dunno if it makes a difference havent tried it out yet,meant to make more noise but who knows lol
Old Feb 12, 2014 | 07:20 PM
Ive got a cone filter to try on but I need an induction pipe to fit the massive airflow meter lol.
Old Feb 12, 2014 | 07:27 PM
I wired a switch in so that I can open the boot when the engine is running. I wired the light in the switch up too.
Old Feb 12, 2014 | 07:32 PM
I also fitted a amp and some 8 inch subs to the rear speaker pods . It sounds well.
File Type: jpg
bagginsRSturbo
I think roose and samco make the hose not cheap $40 I think
Old Feb 12, 2014 | 07:33 PM
Size:  66.0 KB Put some big washers behind the amp to secure it.
Old Feb 12, 2014 | 07:34 PM
Im sure I seen one on amazon for about 8 quid.
Old Feb 12, 2014 | 07:36 PM
bagginsRSturbo
Really thats a bonus then, i like what you've done with the sub
The ice stuff was just shit I had lying about in my attic so I just thought I would try it. Some of the pumas had the option of having subs fitted to these speaker pods and an amp fitted too.
Old Feb 12, 2014 | 07:55 PM
bagginsRSturbo
I never knew that lol, least this way you wont take up boot space
Old Feb 13, 2014 | 07:38 AM
Yeh the option had the speakers/subs fitted where ive got mine fitted.
Old Feb 13, 2014 | 07:40 AM
This rear door card is off a racing puma and you can see the grill in the bottom of the panel.
Old Feb 13, 2014 | 05:13 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Be careful with cheap silicone hoses, very much inferior quality and most come in alarmingly smaller than they should be.
Old Feb 18, 2014 | 05:52 PM
Ive got a 3 n a bit inch wide pipe from work so I will see if this will fit.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
youngben
Sep 27, 2015 09:37 PM
Marv888
Sep 26, 2015 03:44 PM
