Rear beam bushes
The rear beam on my 3dr has been polybushed by a previous owner, I've read and been told that this is a bad thing to do due to the original bushes having a bearing in them so was considering either changing them back or getting another beam that's still got standard bushes in, but what effect do the polybushes have on the car?
Cheers, Karl
Cheers, Karl
It's all polybushed James, the mounts and the arms, I know the mounts are ok to polybush, it just seems to vibrate a lot more than my old sapph used to under acceleration, my sapph went from standard beam with standard bushes to an adjustable beam with rose joint inner and outers on the arms and was always fine. Just wondered if this is one of the problems you get with polybushed rear arms?
Karl
Karl
Get that diff mount changed and replace the poly bushes in the rear arms with standard cossie ones.
Out of interest can you tell if the rear arms are poly bushed when you drive the car.Ive heard a few people say they cant tell the difference between the standard bushes and the polys.
I've still got the poly diff mount that was on my sapph, was in 2 minds wether to fit it or not as thought it might make it worse but I think I'll give it a try mate
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
