Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
cosworth oil pressure / oil cooler problem?
Old Nov 12, 2013 | 07:10 PM
petemos's Avatar
petemos
Default cosworth oil pressure / oil cooler problem?
I have recently put a 9 row oil cooler onto my escort cosworth. I put the sandwich plate on the end of the arm between the filter. Now sometimes when starting the car the oil pressure takes a wee while to build up and the engine is knocking. Once the pressure is up its fine. I've noticed that it must be the oil cooler draining back into the sump as the oil level is rising above the normal mark and it must be the extra oil from the cooler and pipework......any ideas?don't want to feck my engine!
original
Jan 30, 2022 08:20 PM
Chas
Sep 21, 2015 08:57 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Aug 14, 2015 07:29 AM
mattman1234
24
Aug 1, 2015 11:46 AM
