Cosworth wiring
Old Nov 8, 2013 | 02:27 PM
simon206wrc's Avatar
simon206wrc
Default Cosworth wiring
Hi All,
Just having some problem with wiring. can anyone tell me what the 2 wires are on the photo iv attached hanging down. there is 3 in total coming from the next to the injector rail 2 black and one white. i know 1 black goes to the distributor and one to to crank sensor but not sure on which colour, and dont know where the 3rd wire goes.
Regards
Simon
Old Nov 8, 2013 | 02:31 PM
simon206wrc
Sorry cant get a photo on here it wants add it from a web address and i want to load it from my pc ?
Old Nov 8, 2013 | 02:46 PM
opposite lock's Avatar
opposite lock
Use something like photobucket to upload here.
Old Nov 8, 2013 | 03:01 PM
simon206wrc
Old Nov 8, 2013 | 03:04 PM
simon206wrc
Cant do this photo up load. dont understand it
Old Nov 8, 2013 | 04:07 PM
opposite lock
I,ve only ever used photobucket, just open an account and upload your pictures there , then use the option for forum uploads, copy the 'url' and paste here.
Old Nov 8, 2013 | 06:04 PM
costina's Avatar
costina
Live long and prosper!!
Crank sensor white
dizzy phase sensor black
Throttle position sensor 3 wire plug
www.bigturbo.co.uk
Old Nov 8, 2013 | 06:12 PM
simon206wrc
Thanks costina,
So I'm wrong there is 4 plugs coming from next to injector rail. 2 black 2 pins 1 white 2 pin and 1 black 3 pin. its a black 2 pin im having trouble locating ???
Old Nov 8, 2013 | 06:15 PM
costina's Avatar
costina
what loom you using ?
Have you connected the coolant temp sensor at the rear of the head?
Old Nov 8, 2013 | 06:18 PM
simon206wrc
Im having trouble getting it to fire up, it keep trying to start but then dosn't I'm not sure if this wire is anything to do with it. iv replaced the crank sensor and checked spark and fuel... its annoying don't know what else to try ???
Old Nov 8, 2013 | 06:23 PM
simon206wrc
Its a 1993 sierra cosworth standard loom. iv check all wires and dosn't seem to be anything missing just this 2 pin black plug coming from the injector rail ?
Old Nov 8, 2013 | 06:24 PM
costina's Avatar
costina
You need to go back to basics Simon.
when you turn ignition on does the fuel pump prime?
Does the amal valve click( if you have one)?
do you have fuel at the rail?
do you have spark?
If you get a feeler gauge and touch the crank sensor (with ignition on) the fuel pump should cut in
Need some pics really it would help also look at that site.
Old Nov 8, 2013 | 06:26 PM
costina's Avatar
costina
Strange being a 93 that's a 4x4 loom so it could be for a knock sensor use that site and check for L8 ecu wiring.
Hope that helps
Paul
Old Nov 8, 2013 | 07:20 PM
simon206wrc
Could be the Lama sensor ? iv got 2 pumps with swirl pot so these are wired up direct. iv tried all sorts its been going on for months and dont know what to try next ?
Old Nov 8, 2013 | 09:45 PM
costina's Avatar
costina
Lambda sensor would be a 3 wire triangular plug it won't make any difference if its connected or not.
if your using a 4x4 loom do you have the 2 large multi plugs still in the loom?
Was it running before? have you changed anything cam belt dizzy ?
non starting is either no fuel spark or crank position sensor isn't working or phase sensor in dizzy.
join photobucket and put some pics up or you can sent via email to me just drop me a pm
jdsjojo
Aug 26, 2015 10:09 PM
Aug 14, 2015 07:29 AM
jdsjojo
Aug 1, 2015 08:50 PM
