Leak off pipes!!!
Can anyone enlighten me on how the fuck i remove the leak off pipes from my 02 mondeo. I dont mean the 4 clips off the base of the injectors but the other end with the little black and white clip thing. Or it easier to replace the lot by splicing new fuel lines and fittings.
Thanks in advance.I need to get this fixed as the wifes starting to get ideas on a new car!
White bit 'just' pops out of the connector, the two little bits need pushing in from the back then you can lever it out.
It doesn't come out completely.
Put a pic up of the connector if you can.
