The 7064 is what you need. I tested a gtx3071 and at 3800rpm the bw had 335ftlb more than the gtx.
Mark
Do you sell these? How is the fitment? Could you possibly upload some pictures of this?
Originally Posted by Kitchen Devil
What BW turbo would you use for approx 500 BHP Mark and are these a better bet than my GT3076.82 I have at the minute?
What are the costs of the BW's as well?
The difference is in the turbine wheel design; an inconel-type (read steel) will never be able to compare with titanium. Old style turbine wheels have leakage through the wheel, while the new BW has a "backing plate" much like the compressor, forcing more exhaust to drive the turbine rather than just leaking through the blades.
VS
with the cossie manifold being open scroll it will loose a lot of the edge the efr series has imo.
my gt40 on rb27 doesn't run true twin scroll but being a straight 6 and the mani being divided 123 / 456 due to the firing order it keeps the pulses separate.
its only got a single wastegate that just runs off the both banks but imo that is irrelevant as the turbo has already spooled upto 1.7 bar before the gate opens and then lets the 2 flows collide by which time its irrelevant anyways as ive hit full boost and maintained it.
unless theres an open scroll t3 housing option I wouldn't bother, even then no doubt a proper twin scroll set up will help a lot especially on a 4 banger.
And according to the compressor map it can produce almost 40psi at the amount of air where the Cossie reaches 4000rpm; hence why Mark says he experience extreme amount of torque statically that is.
I think this turbo will change things as it will surely destroy any stock T5 and mt75
Martin what type you going to run and is it on a manifold. A 7064 may be a bit small on a large capacity engine.
Mark
At the moment the car has a GT3071 fitted on the std 2wd manifold and its nice and drivable, I was going to adapt an ex gate 7064 with the larger ex housing onto the stock manifold and see how they compare. I had been told by the dealer that they're similar sized turbos but I haven't checked anything yet, my main reasons for wanting to try one is because they are now quite cheap to buy (comparable to the GT series) and readily available from UK suppliers.
Once you get over all the little bits that make it fit you will be stunned at the diff but do throw the 2wd manifold in the bin.
Ok Will do, its purely out of interest really as for me it worked out the same cost as a GT30, once you add in all the bits. If and when I want a bit more power all i'll have to do is change the manifold.
