anyone work for mercedes?
how do i remove the gear selector module from a 2000 a class?
apparently it's some sort of ecu by the gearstick so any ideas?
cheers peeps
cheers peeps
I guess it says f on the dash? as they go quite often on the older a class chassis 168, you have to take all the centre console but out the. there's 4 Allen keys that go around the gear module, then a cable which has a clip mechanism on it from under on the box, they don't need to be programmed either. it's a lot of messing around as need to take ash tray out hand brake leather loads of hidden screws etc. but can be done pretty quickly
can't get that cunty clip off, even used a slide hammer on the bastard and still no joy
everything else is off, i've even put the bolts back in again with no luck, the fucker ain't moving
any ideas? is it locked into place until the selector is in N or something stupid like that?
any ideas? is it locked into place until the selector is in N or something stupid like that?Last edited by Harryh24; Nov 10, 2013 at 02:37 PM.
well, i used a hammer as suggested earlier
but i used it to pry a pry bar up underneath the clip, and once it was out it was all relativly easy, even the adjuster is easy and not as nightmare as haynes has made out
just hope it all goes together properly again
Rstar_man
143
Jul 20, 2020 11:16 PM
bassboy
Aug 8, 2015 10:21 AM
