Gearbox/prop issues
Old Nov 6, 2013 | 01:58 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Default Gearbox/prop issues
It looks like i have an escos prop as the end wants to go right through the doughnut.
however the doughnut i have bought is the fatter sapphire one with bearing.
also the bolts in the gearbox are the longer sapphire ones.
so im looking for easiest way out of this. Buy escos prop but can i use the existing saphire bolts?
where do i buy escos bolts?
cut bearing/middle out of prop doughnut i have?
Old Nov 6, 2013 | 02:53 PM
rog's Avatar
rog
If you have another box available that's different, you could swap the transfer casing part over?
Old Nov 6, 2013 | 03:16 PM
Ebonycossie4x4
i dont have another box mate and its in the car now so im not taking it back out haha.
poss best solution is thin doughnut and the shorter bolts but dont know where to get bolts from.
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
