Need info asap on the OFAM ecu's
Had a mate drop his Escort turbo round today for me to fit his new ZVH engine and fit his cossie management off his old car onto this one.
But the Escort already has an efi conversion and it's been been done using a full Efi XR3i loom and i said to him it seems a shame to chop the engine loom part out to replace it with the cossie one so i suggested OFAM or something that direct plug in
Just need to know:
Where to get it from
How much are they
Who maps them
Anyone got a contact no. for someone in the know please?
Gary 07946367994
Just need to know:
How much are they
Who maps them
Gary 07946367994
Just make sure the xr3i loom has had the pin out changes too work with ofab (turbo) and it should be plug and play
While your there factor in a aem wideband and aem boost solenoid too make the most of it
I've emailed boost monkeys so hopefully he'll get back to me asap. It's on OFAC at the mo so will need the pin change doing but it goes ahead, i think the plan was to run it in on his OFAC then fit / map the new ecu at the same time.
fingers crossed
It's a good idea and in my opinion it's better than cossie management
All I ever see is people complaining of poor fueling on the cossie management conversions, and studabear above took his off too fit m/s
Sell the cossie stuff and get a ofam ecu with aem wideband so you can run closed loop, and a aem boost solenoid for full control
This is what I'm saving for on my zetec turbo
why the wide band and boost controler? obviously wideband to keep an eye on fuel etc but can boostmonkeys do any extras to benifit u if u do that or is it just for own peace of mind.... also boost solenoid? cheers mark
Originally Posted by Karlos G:
If anyone is interested this is the wire swaping you need to do for XR3i/XR2i (1AFA) to FRST (OFAC)...
1) Pin no. 8 (brown) needs moving to pin 27, which is empty (CO adjuster signal wire)
2) Pin no. 27 (brown/yellow) needs moving to pin no. 45
3) EDIS Module pin 2 (blue/yellow) may now be disregarded as it is not used by the 0FAC ECU (pin 28 on ECU).
There are no MAP sensor pin changes as the OFAC MAP sensor is the same plug as the 2i MAP Sensor, so just plug and play.
But... only on some conversions it seems!
Some work plug and play and others need the above doing, maybe there are some subtle differences in the ECU/loom's of different years I don't know?! But I guess if it doesn't work one way then try it the other! lol
I'm lead to believe it's just plug and play with the original ford efi set ups?
Karlos G is the man to speak to, his number may be in his Facebook page frenzy performance tuning
Got you pm thanks mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
