Drive shafts zetec
Old Nov 1, 2013 | 06:17 PM
Pockets2012's Avatar
Pockets2012
Default Drive shafts zetec
Right what is the best shafts to use I'm aim for 400 bhp and using what I thinks is mtx75 gear box wit ch came out the mondeo
I want to try get these once I weigh in the shell
Advice please fellas thanks
Old Nov 1, 2013 | 06:18 PM
Pockets2012
Can't remeber who told me but aprently the rs1800 is ok ??
Old Nov 1, 2013 | 06:20 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Yeah they fit. What LSD you using?
Old Nov 1, 2013 | 06:24 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
What car is it in?
Old Nov 1, 2013 | 06:27 PM
SBT83's Avatar
SBT83
Mk4 fez I think?
Old Nov 1, 2013 | 06:30 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
No standard shaft will fit if he is converting it to mtx75.it will have to be half mondeo or focus 2.0 and half fiesta shaft
Old Nov 1, 2013 | 06:31 PM
Pockets2012
Or
120797063962
That's eBay
In mk 4. Fezz
Old Nov 1, 2013 | 06:37 PM
SBT83's Avatar
SBT83
Didn't the rs1800 come with mtx?
Old Nov 1, 2013 | 06:40 PM
frsjon's Avatar
frsjon
i wish lol as rob said,will have to have some made for the mtx.....bc or ib5 would be fitted to a rs1800 as standard
Old Nov 1, 2013 | 06:46 PM
SBT83's Avatar
SBT83
I'm thinking the wrong thing guys. Sorry.
Pockets2012
Balls ill gas to buy another shaft from gear box lol as I sold it thinking didn't need it hahaha
Old Nov 1, 2013 | 06:51 PM
Pockets2012
Lol thanks for trying lol I'm gonna be nagging every payday lol witch part this witch part that lol like I said it my first project so sorry if I annoy you all
Old Nov 1, 2013 | 06:53 PM
Pockets2012
Do it's would be drivers mondeo gearbox the fiesta rest but what about passenger ??
Old Nov 2, 2013 | 10:17 AM
Pockets2012
This is the gear I have with engine out the mondeo
190707710379
eBay numbers
Old Nov 2, 2013 | 04:15 PM
Pockets2012
http://www.reco-prop.co.uk/uprateddriveshafts
I just found this hope this helps other people I also rang
Elite racing trans 01782 280136
He said they can make one offs from 150 to any strength to fit anything
I hope this help too git the number from that trolley fiesta
Old Nov 2, 2013 | 06:41 PM
SBT83's Avatar
SBT83
Or alter the length yourself and sleeve the weld and pocket the Ł195
Old Nov 2, 2013 | 07:18 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
I would rather use custom made shafts over welded up ones.for that price it isnt worth the hassle of getting them welded up
Old Nov 2, 2013 | 07:24 PM
SBT83's Avatar
SBT83
Vey true. But at the same time you could mix and match driveshafts to do the same job as custom ones
Old Nov 2, 2013 | 07:26 PM
Pockets2012
Well one I think would be better for strength but that my opinion
One say well all have to put up a zetec tuning guide and fiesta conversion guides
Old Nov 2, 2013 | 07:34 PM
Pockets2012
Witch could you mix and match
The drivers side could be mondy from gear box some had adapt fiesta to fit but passenger side ??
Old Nov 2, 2013 | 08:08 PM
SBT83's Avatar
SBT83
What bout mk5 escort drive shafts?
Old Nov 2, 2013 | 08:11 PM
Pockets2012
Anit they longer than fezz and will the fit hub or mtx75 gear box ??
Old Nov 2, 2013 | 08:14 PM
SBT83's Avatar
SBT83
I don't know bout the cv splines but it may be worth asking a guru on here
Old Nov 2, 2013 | 08:16 PM
Pockets2012
Where's he at lol gotta ask try save some money for other thing lol
Old Nov 2, 2013 | 08:19 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
You will need a mondeo or 2.0 focus half shaft on the o/s then custom ones from that to the hub and on the n/s aswell because there isnt any factory shafts with the correct spline and lengths that work.i mocked up one for the o/s ages ago and it was about 3inches shorter than standard and had to have mondeo spline on the inner so the inner cv joint fitted and fiesta outer spline for the outer cv joint and the n/s shaft was about 1 inch shorter than the o/s one with the same ends as the offside one
Old Nov 2, 2013 | 08:39 PM
Pockets2012
A lot of messing around then lol
Old Nov 2, 2013 | 08:45 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
Yeh it is, eaisest way is to get a complete set of mondeo shafts and fiesta shafts and cut and shut it all together, how much power and engine spec are you using? I used a bc box running 350bhp in my old mk2 fiesta and the box was ok, but think I was lucky, my mk3 has a mtx in it and wasnt a straight foward fit but worth it for what I will be using the car for
Old Nov 3, 2013 | 12:04 AM
Mk4 Rick's Avatar
Mk4 Rick
This is a beast of a car and looks evil
Old Nov 3, 2013 | 12:12 AM
SBT83's Avatar
SBT83
That's what I was talking about Rob with cut and shut and sleeving the shafts. No doubt a weld is the weak point of the shaft but a weld is still strong plus with a sleeve it's up to the job. I used to run red tops in corsas this way and had no troubles after sleeving.
Not doubting your skills at all mate! Your a legend
Old Nov 3, 2013 | 12:31 AM
Pockets2012
If he can do it ill be more than happy to pay him but I really wana try for 400bhp out of mine
Old Nov 3, 2013 | 01:27 AM
SBT83's Avatar
SBT83
For the spec your chasing scrap what I said and buy customs.
Old Nov 3, 2013 | 06:07 AM
Pockets2012
But even still this is all good info for other peeps lol
JK12
33
Apr 26, 2021 12:09 PM
Kam B
Sep 24, 2015 10:40 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
little bram
Sep 7, 2015 11:59 AM
rsstav
Sep 7, 2015 04:43 AM
