Injector loom plugs
Anyone know where I can get new injector loom plugs for my Cossie?
Mine are yellow at the moment and spoil the new look I'm going for.
Want them black if possible
Cheers billy
Cheers billy
Just quickly done some sums, if anyone is interested, I can offer a kit consisting of:
35 Way ECU Connector (to suit L1, L6, L8 & P8 ECU's)
Connectors for:
Crank
Phase
MAP
TPS
Air Temp
Water Temp
4 x Injectors
Knock
Coilpack / Coil
All in black, complete with pins & boots.
As a PF price - how does Ł64.95 including VAT & Delivery sound?
Or - if you'd prefer just the connectors (without the ECU plug) - Ł39.95
Connectors for:
Crank
Phase
MAP
TPS
Air Temp
Water Temp
4 x Injectors
Knock
Coilpack / Coil
I also stock Raychem Spec 55 wire and Raychem DR-25 heatshrink - all the ingredients to make yourself a very high quality wiring loom.
It's all on the webshop @ www.willpedleyracing.co.uk
DixieTheKid
11
Jun 6, 2020 11:20 AM
155lee
Oct 24, 2015 11:11 AM
timsrs
22
Sep 24, 2015 08:14 PM
